The ones with the sharp points appear to close off the rear of the cab between the seat belt mounting and sides,overlapping the floor pans. The ones in the picture I have not figured out. Did FFR give you a link to some photos in Dropbox if not ask them to do so. It has some build photos.
Updated these two pieces are installed to the rear cab corners once the body is mounted.
