06-21-2018, 02:25 PM
#281
1932
You get only the glass in kit. I will ask neighbor that does glass repair.
Have decided to go ahead and put glass in as inside paint is single stage and outside paint is base-clear coat .
Cool, My inside paint is two stage and will be satin on the interior to alleviate any unnecessary additional glare. I have SikaTack windshield glue system which i will most likely use to glue them in. I will also see if its worth getting the local windshield repair person to install it as well. TY!
06-24-2018, 11:02 PM
#282
Been working on door windows, went to the box i have been carefully on the shelf, got box downe and NO GLASS! Dam i will call FFR about it. I did not look or take out the glass so as not to mess it up.
06-25-2018, 11:47 AM
#283
Found the glass! FFR said it was in box 31 in a box of its own, so look for a different box with glass only. That is what happens when i put things in a safe place!
06-28-2018, 02:38 PM
#284
Working on doors & windows, windows perty good and built up Ds with fiber tec, liking that. Will start to fab the door tops with aluminumIMG_8106.JPGIMG_8108.JPGIMG_8109.JPG
Having trouble with red top battery, will not charge and stay a reasonable %?
07-03-2018, 11:23 AM
#285
The battery was no good (new), exchanged and all is good.
I have GPS speedo, will it work through the aluminum on dynamat?
07-03-2018, 11:55 AM
#286
Tom,
My GPS speedo works fine under the dash.
CVOBill
07-03-2018, 12:06 PM
#287
I have roll cage so has to go on top of that, and dynamat in top of cab. Will mount on top of middle bar and can put forward under fiberglass but would like to have it back some but will be under dynamat.
07-04-2018, 07:43 PM
#288
Put in all the dynamat( as used in big trucks & tractors), the floor piece in front of seats pulls out for cleaning. The line on side of trans tunnel is where the top comes off, didn't think i could find it if didn't splice it.IMG_8110.JPGIMG_8111.JPGIMG_8112.JPGIMG_8113.JPGIMG_8115.JPGIMG_8116.JPGIMG_8119.JPG
Made sill out of angle aluminum.
07-07-2018, 12:02 AM
#289
Did some cutting on front fenders , so that my big tires clear when at full turn.IMG_8120.JPGIMG_8122.JPG
Had a small crack on hood so i ground out all inside fiberglass and did over. It was some of the first glass work i did and had some problems then, found air pocket on both sides.IMG_8121.JPG
07-08-2018, 11:56 PM
#290
Good day! Our son helped put in the front & back glass,this is what we usedIMG_8131.JPG The back was very eazy. Front not so much, because i wanted to fill around outside of glass to body. I went around the cab with a bure in the drill so as to get down to fiberglass and have it ruff for glue.
Need a lot of rags or shop towels, and acetone will cut the glueIMG_8127.JPGIMG_8128.JPG
Working on door handles, think i have a fix for them, more to come.
07-09-2018, 07:03 AM
#291
Very nice work on the glass
07-09-2018, 08:54 PM
#292
OK here are pics of the fix for the door handle. IMG_8132 - Copy.JPGIMG_8132 - Copy.JPGIMG_8133.JPGIMG_8134.JPGIMG_8136.JPGIMG_8137.JPGIMG_8141.JPGIMG_8142.JPGIMG_8143.JPGIMG_8145.JPGIMG_8147.JPG
The stop needs to be strong so will not bend, you can use thicker or thinner bushings on stop tp fine tune. I used the backing plate to mark holes for handle so it lined up with stile line.
wrp thanked for this post
wrp liked this post
07-09-2018, 09:05 PM
#293
07-14-2018, 12:03 AM
#294
I got the car out of shop and put 19 miles on it!! Had to pull in and lift the rear about one 1 inch then all good. need tune it is on a start up tune that is good to drive, will make appointment for to get tuned.
All worked good but the reverse lock out, need to run that down it is hard to get in reverse.
I will get son to put up video later.
07-14-2018, 09:50 AM
#295
07-14-2018, 12:08 PM
#296
![](https://thefactoryfiveforum.com/attachment.php?attachmentid=49655&d=1452637671)
1932
Wow, that's looking good! The headlights, repeaters and rear lights are all a nice touch. Stance is perfect!
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
07-14-2018, 01:37 PM
#297
What a great look! I love the theme you went with and look forward to seeing it finished.
07-14-2018, 03:41 PM
#298
This car drives very good!! Wife and i went to town to eat it rides softer than my mini, she went to sleep on way home.
Running very rich till tuned.
07-17-2018, 07:46 PM
#299
Was to get tuned thursday but alternator went bad, had to order parts. So week or so.
07-18-2018, 07:50 AM
#300
Congrats the car looks great.
CVOBill
07-18-2018, 12:41 PM
#301
Video on facebook
Thomas H R Platter
wrp liked this post
07-20-2018, 09:53 AM
#302
For any one that would like to use the ford alternator, the alternator that is for automatic cars comes with solid pulley. When i was looking for a one ever one told me no!
07-24-2018, 01:48 PM
#303
Had family over and gave rides most of afternoon, any thing to go drive!
Built a over flow tankIMG_8165.JPGIMG_8166.JPG The only place i had left to put any thing!
Have 180 miles on car, more later.
07-25-2018, 11:39 PM
#304
Two things (alternator went out after new regulator. about 100 miles or so with gage fluxing. Will take back and find out the problem)
and ( the t56 reverse lockout module did not work right, put new one on and it worked then the module grounded, checked all wiring good so put a interrupting switch on shifter all's good.)
A note on rostra cruise control, with lockout wired in it would not set a cruise, after that uas out the cruise works very good.
07-27-2018, 11:10 AM
#305
I can not get the Speedhut gauges to set the warning lights or fuel gage to set right ohm. Anyone had this problem?
07-27-2018, 01:50 PM
#306
OK how many times do we have to read the instructions to get it right??
Only plug setting switch into left side of gage. I looked at the one that worked and it was on the left and others on right, sooo read instructions!
07-27-2018, 02:31 PM
#307
This is my reverse lockout, no more micro electrons. Just a push button to use with side of hand.IMG_8168.JPG
07-27-2018, 05:17 PM
#308
1932
Why would anyone read the instructions? Where is the challenge in that
07-29-2018, 11:23 PM
#309
As you all know i have permanent top, so would like windows to work good! That is harder to get than doors. Hours and have one that is fair, it is tight on top corners but not all the way, had to have runner to back of window then put spacers were window is bolted to works to get the top in. Pics later.
wrp liked this post
07-29-2018, 11:51 PM
#310
Looking forward to the pics, wrestling the same issues
07-30-2018, 11:06 PM
#311
Ok, the window workIMG_8177.JPGIMG_8176.JPGIMG_8171.JPG pics show door top aluminum with hagen wisker strips, all will be worked to fit door top.
The washers usedIMG_8172.JPG as spacers, may need to take one or so out, you can use fender washers for thinner spacers.
The last pic shows front runner that i moved back so glass is full in runner,spacer between bracket and runner.IMG_8175.JPG
07-31-2018, 02:06 PM
#312
Whent to CHP and was told i had to go to BAR first before he could give VIN#. I have a problem with alternator charging, new regulator but no charge. Ford control pack with three wires to ford alt, worked to start then would over amp then quit. New regulator then would not hold steady amp and quit. I will check for damaged wires--then???
08-02-2018, 10:40 PM
#313
Coyote engine (2014) with ford control pack, and ford alternator that came with engine. Can anyone tell me what the three wires to alternator do? Or how to wire around the ECM?
Have new alternator good wires but no work!
08-03-2018, 11:38 PM
#314
SOOO the alternator went and welded together, belt gone. Bought new alternator for auto trans ( solid pulley) put it all on and did not work as we were looking for. Today called Ford Racing gave all info and was told to NOT plug in the three
wire alternator plug! sems to work but the pulley is smaller and i had the belt for clutch pulley , it ate belt, got hot and waited for son to get belt . Car back in shop. Will get a shorter belt tomorrow.
08-06-2018, 11:03 PM
#315
Had to take all the pulleys off and clean groves, full of belt! 3/4 shorter belt and just bat wire on alternator worked but would heat and pop 150 amp breaker , got new breaker and all working good!!
08-10-2018, 09:12 PM
#316
I have to go to a different CHP office to get VIN#. The one i went to the officer will not do the VIN because he says i have a race motor and not Ca. admission legal!! Wants nothing to do with BAR or SB100.
So DMV can't do my SB100 # without the VIN #.
08-16-2018, 11:05 PM
#317
I just keeped working with CHP and he went to DMV and got my SB100 number!
08-18-2018, 09:18 AM
#318
Off to AED to get the engine tuned, been running on a start up tune, so this should be fun.
08-19-2018, 04:49 PM
#319
437.5 hp on dino. RWH
Have to do work to get intake heat DOWN.
Need IRS boots, both outside boots came apart and made a hell of work!
Post Thanks / Like - 0 Thanks, 3 Likes
08-20-2018, 10:17 PM
#320
Talk to FFR and was told that 2016 mustang should work. Ordered boots and axle nuts at ford. Cleaned grease. The outside axle CV comes off with hammer on inside part- spring clip.IMG_8181.JPGIMG_8183.JPGIMG_8178.JPGIMG_8184.JPG
Ready for parts!
