0
Originally Posted by
cv2065
I like the mounting through the 2x2 frame. I have the thicker firewall from ffmetals, so hopefully it will cure any flex when accelerating. Anyone have a diagram of the whole setup as installed?
Here's how I did mine. I too would suggest to wait until the motor is installed so that you can get the correct dimensions. Mine's a little different as I made my own firewall and linkage. The firewall hangs lower than the 2x2 and it's .125" thick. So I mounted my linkage to the firewall itself. HTH a little. It's a great addition to the build!
Mechanical Linkage Album
My photos are at:
My Flickr acct
Videos are at:
YouTube Videos
