![BluePrint Engines](https://www.factoryfive.com/wp-content/uploads/2015/12/BluePrint_Engines_Factory_Five_banner_ad_revised.gif)
0
0
Grill height
Hows this for suckiness, first time the car moves under its own power is bringing it home from the shop where we figured out all the wiring problems, fuel problems, etc. Loading onto the trailer the bottom of the grill catches and digs in pushing the radiator back into the upper control arm bolts. Two leaks. Haven't taken it out yet to see if the radiator can be repaired. So close, then two steps back.
The bottom of my grill is 4.25 inches off the ground. whats everyones grill heights.
Originally Posted by
jimmish
My grill is 4.0 inches off the ground. Definitely need to be aware of speed bumps, curbs etc. A couple of close calls so far but no damage.
Pulled the radiator and it looks like it may be able to be tigged. one tube on one side, two tubes on the other, about 2' up from the lower tank.
Front and rear frame heights are per spec, may try raising the car .5 - 1" front and rear.
Seasoned Citizen
first time I had mine on the road I ran up to a parking lot bumper, touched the bumper and poked a hole in radiator.
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
