Thanks Thanks:  2
Likes Likes:  2
Thread: Master Cylinder not bolting up
    Mar 2018
    Installing Wilwood pedal box and reverse mount masters. Pedal box mount in book picture looks nothing like this one, (looks like the one in the cobra) Master cylinder hits bracket and wont slide on bolts? Anyone else have this issue ? Cant get hold of tech support....
    Mar 2018
    Moved the assembly to the top of bracket instead of below it and everything bolts up, I just hope this doesnt raise my pedals up to high or interfere with anything else.....
    Aug 2013
    Gatineau, Quebec, canada
    Here is a shot of how our setup, not sure why you needed to sit it on top. Be careful of the body clearance after.
  4. Likes Miltbuilt liked this post
    Mar 2018
    It looks like the bracket on your car is a lot wider than the one on mine on the right hand side yours has a piece that comes off the square tube that your pedal assembly bolts to mine does not have that
    St. Louis, MO
    I talked to FFR about this a couple of weeks ago. They changed the frame mount for the pedal box and yes the new design requires the pedal box to be mounted from the top.
    Wibby
  7. Thanks Miltbuilt thanked for this post
  8. #6
    Mar 2018
    Yeah you would think that since we've only had the car just over a month we would have gotten the newest upgraded book
  9. #7
    Senior Member MBB Larry's Avatar
    Feb 2018
    Grapevine, Texas USA
    Thanks for input Guys. This is my project for tomorrow. Would be nice if they would send Corrections and Revisions to Manual as required. Also DISCOVERED my forward Fuel
    Filler Neck hole is NOW in the middle and not on the Drivers Side. So, if you are getting a Boyd Tank like I have, I have to attach a cover, and cut out a new access hole. AND, the Battery Access hole has been deleted. Surprise, Surprise. I have only just begin my build.
    FFR Hot Rod #1106
  10. Thanks Miltbuilt thanked for this post
