Results 1 to 4 of 4
Thread: Garage door and a lift
    Senior Member TDSapp's Avatar
    Frisco, TX
    So guys, if you have been wanting a lift but know the garage door would be in the way. These have got to be the coolest garage doors I have seen. Perfect way to keep the door out of the way with a lift.
    https://www.youtube.com/watch?v=-BkuYt2OOjQ
    this one looks about the same but with a wood front.
    https://www.youtube.com/watch?v=CFFnJcoEg6g
    Check out this youtube video and skip to 1:47
    https://www.youtube.com/watch?v=yKrJZSLvZGA
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Mar 2013
    Fort Collins, Colorado
    Clearance that is gained at the ceiling is outweighed by storage lost along the walls. I would also bet that the seal at the bottom of the door is not as good as a roll-up.
  3. Likes i.e.427 liked this post
    Sacramento CA
    Try www.bifold.com
    Completely out of the way
    Frisco, TX
    Quote Originally Posted by Derald Rice View Post
    You might be right about the seal. Having a seal that drags along the ground will be a fast way to wear it out.
    As for the storage... I don't know... If the door skims along a wall it may only take about 3 or 4 inches. You could always put shelves in front of the door panels.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
