0BEABE99-31B8-475F-ABC4-7BA085CB3482.jpg2D2D9DD2-4EBF-47AE-9EB4-E436F0F38442.jpg30556007-B06D-4D06-B0F5-0904EFC68107.jpg
Worked on windshield and wiper system today.
Nice work on the cubby!
Wow, that is a nice, large cubby. I'm about to do mine and was only thinking of a box the width of the distance between the two inboard roll bar mounts but pretty deep, basically filling in where the battery would sit if I were not dropping it into a box. This has me thinking of some other options. Thanks for sharing.
Lowrod,
Looking really good. I'm actually working on a similar cubby. I got the idea at the Huntington Beach Rally.
Mark
I did similar on my old MkII but I left the 3/4x3/4 tube in place. You can't put as large a solid object in there but it works fine to throw in a folded up coat, hat etc.
Coat/hat storage was the idea, I bent a length of 3/4 tubing to match the body arch. It was then welded just behind the body rolled edge of the rear cockpit. I plan on adding two metal plates to support driver and passenger seat belts.
Love your cubby.
I added a locking access panel to the Breeze cubby kit. While the door is a little small, it won't interefere with the seats.
This is a must have with my wife!
On line at Boat Outfitters.
I removed the white tub to give me access to the Breeze cubby, although leaving it on gives you a nice small compartment. The tub comes off by removing a couple of screws.
