Good evening,
Does the new style 818 bi-xenon have an internal ballast or external, if it did not did you receive them or do we not need a ballast?
Good evening,
The new style head lights are just Hella projector lamps with normal halogen bulbs. You can replace the halogen bulb with any aftermarket HID (xenon) bulb, which will require a ballast. I chose to install LED bulbs (same ones as Frank818):
https://www.ebay.com/itm/80W-8000LM-...oAAOSwHUVa6I0-
Correct, single bulb halogen headlamps (from FFR).
I think LEDs are better, but it's up to what one wants.
Those LEDs above have a small fan to cool them down. There are MANY various other models available, some with fan some with heat sink.
Tracked May 27/July 26, 2017
Build Completed Winter 2021
