Results 1 to 5 of 5
Thread: Can Someone please tell me what this is.
    Onalaska, TX
    On page 396 of FFR manual Rev 2, it shows a verticle angle coming off the door frame by the door latch end. What is it and what is it used for?
    Oct 2014
    Vermilion, OH
    I just looked on the electronic manual I have and it must be different than the paper manual. Do you have the electronic version?
    CVOBill
    Aug 2013
    Gatineau, Quebec, canada
    Quote Originally Posted by Dodgeman View Post
    On page 396 of FFR manual Rev 2, it shows a vertical angle coming off the door frame by the door latch end. What is it and what is it used for?
    Its the channel for the Power windows, you can see it better in the instructions for the power windows on the PDF page 14, here is the link for the PDF for the power window setup and installation: http://www.factoryfiveparts.com/cont...er-windows.pdf
    Onalaska, TX
    AJT,
    Thanks, I don't know why FFR doesn't include this in the manual. even if the builder doesn't want to have side windows, it would help the ones that want the windows instead of looking forever for information.
    Nov 2015
    Elverta, CA
    Bob, are you referring to the part just below the hose clamp with the hole and slots? Is fo, that's where the striker bolt bracket bolts. See page 406 which is only pic that shows it. Hope this helps.
    Tomorrow
