Earlier this week, Wednesday morning before we headed out for Cruising The Coast, I called Mark Reynolds at Breeze Automotive and ordered 4 side pipe wedge plates.
This evening they showed up in my mailbox so you all know that I had to start swinging wrenches, even though I'm tired as hell after a week of cruising.
Anyway, the wedges worked perfectly and my side pipes are now mounted and spot-on perfect because I have his wedges.
The moral of the story, If You Need Something & Mark Has It, Then It Will Work & Work Well!
The other piece to the puzzle is that it will get to you as quickly as promised.
If you need to tweak your pipes, then get these wedges:
https://www.breezeautomotive.com/pro...egory/exhaust/
Thanks Mark!
