Results 1 to 4 of 4
Thread: Koni adjustment
    Mar 2017
    Norway / Merritt Island FL
    Koni adjustment
    What initial adjustment do people use for the basic Konis?
    I am preparing for a new work session on the type 65. All the suspension parts have arrived. I would like to have a shocks adjusted before I install them. 347 Ford with IRS. I understad they are supplied adjusted to the softest position.
    Quote Originally Posted by Sigurd View Post
    Not necessarily. Although they are usually on the soft rebound setting out of the box I have found some that are not so you are wise to check them. My experiences are with Roadsters running 3 link so may not be the same as your IRS Coupe but with those when using the factory spring rates I set the front to soft and the rear to one click up from soft (they're a little bouncy in back on full soft in my opinion).
    Mark Dougherty's Avatar
    Hershey PA
    New irs or old
    New IRS do as Jeff stated
    Old IRS full stiff
    Fronts leave at full soft
    The traveling Builder
    717-773-5624
    Mar 2017
    Quote Originally Posted by Mark Dougherty View Post
    New irs or old
    Old IRS full stiff
    New IRS. Rear: one click up; front: soft.
    Thank you gentlemen!
