Results 1 to 13 of 13
Thread: Front tires rubbing when turning
    Nov 2016
    I am using a 07 wagon donor but replaced the LCAs with aluminum. The control arms were mounted to the inner holes and the tires rubbed when turning hard. I moved the control arms to the outer holes and no rub but then there is not enough tie rod left to secure them. Any suggestions?
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Are there longer tie rods available? That seems like the easiest and quickest solution.
    Ray
    Quote Originally Posted by Tamarack18 View Post
    Tamarak18.
    I did the same a couple of years ago. The Baer bump steer kit make the tie rod ends longer. Depending on your front tire width and ride height, you might rub the fenders during body roll.
    Feb 2013
    The only way to make certain you will not rub or actually crack the body fender during turning / compression is to raise the fender 1.25 inches. This is on the Gen I 818 front. Perhaps FFR raised it up on the Gen II. Here is a picture:
    Fenton MI
    The wagon's were slightly narrower than the sedans, assuming the aluminum LCAs were for a sedan and might be the cause for running out of threads on the tie-rods.
    Factory Five 818c #456
    Jan 2018
    The Bear bump steer kit make the tie rod ends longer.
    Is this the kit you are referring to?
    https://www.jegs.com/i/Baer-Brake/13...660+4294828659
    Quote Originally Posted by DND View Post
    Baer bump steer kit from Summit is #BAE-3851001
    https://thefactoryfiveforum.com/show...l=1#post239655
    Edmonton, Alberta
    You can also piece together a bump steer kit from speedway for cheaper. I believe there’s a list somewhere here on the forums, I also show all the part numbers in one of my videos.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Jan 2018
    Adam I got all the part numbers from your video.
    I am finally getting around to doing this now that I've fixed my lower control arm locations and semi-corrected the ride height of the car.
    But from all the different threads on this topic I'm still a little unclear on one thing, do the Pinto tapers fit or not fit? And did you just drill things out and use a straight bolt instead?
    Does even the Baer kit require modification to use?
    Senior member
    Carlsbad,Ca
    I have just installed the Bauer kit and it requires no modifications.
    Simply install it.
  11. Likes Mitch Wright liked this post
  12. #11
    Mar 2014
    Hingham, MA
    The Pinto tapers do not fit. The Baer kit fits, but I found that I needed longer pins to completely correct the bump steer. This may not be the case for all cars. I ended up having the Pinto tapers turned to the correct taper. Drilling and using a straight bolt should also work.
  13. #12
    Edmonton, Alberta
    Didn’t drill anything, the taper doesn’t quite fit all the way but it’s not going anywhere.
    818 SRX - #91
    Arrived 01/02/2014
  14. #13
    QC, Canada
    Ditto. Got same kit as Adam, actually I sent him the parts that I bought double!
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
