Results 1 to 12 of 12
Thread: Maiden Voyage - first go kart run of 8650
    On a roll Al_C's Avatar
    Wheaton, IL
    Took 8650 out for its first taste of the road! I finally got a new brake line installed from the junction at the DS front wheel to the PS front wheel on Saturday. Everything is nice and tight – no leaks! I also got new wiring connectors in place (weather pack) for the ignition and fuel pump connections, so it was time to hit the road.
    It wasn’t fast, it wasn’t far, it wasn’t long, but it was its first trip. The worst part was waiting for all the traffic on our street! I just took it up the block, turned around and came back. It didn’t take much to break the rear end loose in 2nd gear on the way back. That was a little unnerving in a car with a “free floating” seat and no belts.
    With its maiden voyage under its belt, I let it run for a while in the driveway. The fan kicked on and there were no leaks in the cooling system. The only problem I found is that my temp gauge isn’t registering anything. Either my wiring is faulty or I did something wrong on the sender. I need to get the tach working correctly, too.
    Next up: get the alignment done then I can take it out for further “testing”. Here’s the video:
  2. Likes BadAsp427 liked this post
    Yay! Congratulations! No seatbelts... yikes!! Thats the only way I can hold my loose seats in place!
    Senior Member broku518's Avatar
    Jupiter, FL
    AWESOME sir! So glad to see this, very happy for you
    congrats Al. Great to reach those build milestones.
    slpro1207's Avatar
    Moorpark, CA
    A very special day to get behind the wheel and drive your creation for the first time. Makes you realize you are very close to cruising down the highway. Congratulations.
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    Wheaton, IL
    Thanks, gentlemen!
    Conesus, NY
    Congrats. Remember my first run!! It feels great.
    Chuck Krueger
    MK4 Kit - Picked up 4/5/14, Complete Kit, 3-Link, Wilwood upgrade, Coyote, TKO 500, First Start 7/25/15
    2000 C5
    2003 C5 Z06
    2007 C5 Z06
    cv2065's Avatar
    Dec 2017
    Nice work! Hopefully I'll be right behind you around Christmas time!
  10. #9
    Good on ya' Al
    Congrats!
    Wheaton, IL
    I watched this again myself and decided it was pretty boring. Do you think I could have gone any slower? As soon as I get the alignment done and the suspension gets tightened up, I'll take it out and go "a little faster". But, this was the first time it was out... Stay tuned for an updated video.
  12. #11
    Senior Member TheBabyBadger's Avatar
    Jan 2018
    North Bay, California
    AWESOME! Can't wait to join that club!
    Gen3 Coupe - SOLD Arrival: 6/21/18 SOLD: 4/12/2019
    Current Vehicle: 2014 SRT Viper (modded to the moon), 2022 TRX, 2022 RS6, E46 LS3 M3
    Current Projects: Superlite/RCR GTR ***FOR SALE***
    @madd_wrapps on IG or www.maddwrapps.com
  13. #12
    Cape Coral, FL
    Nice! We are close to the same point. Maybe next week I can go-kart! As for the temp and oil pressure gauge I talked to FFR and they indicate you need completely independent two wires running to both. My temp gauge worked ok but no oil pressure gauge. I ran separate signal and ground to both gauges and all are good. I suggest you check. They indicate you should not be using the wiring harness wires but running the wires provided in the gauge set for each gauge. New to me and nothing in the instructions. Mine all work fine now.
    Lay on it a bit next time!
