Page 3 of 3 FirstFirst 123
Results 81 to 93 of 93
Thread: Gen 3 "Mystique" Coupe Build
    Member Paul G's Avatar
    Glendale Arizona
    Still working along, big milestone on Friday, Engine and transmission installed. It was a long hot summer so I worked on a bit of wiring inside of the house, here are some pics
    Glendale Arizona
    More..
    Gorham, ME
    Ah yes the good old pool table table!
    Nice progress, always a big one to get the engine installed. Now on to get it running!
    HI Paul.
    Another Coyote in the house. And with A T56 to back it up. Nice touch. Has that been done before in a coupe? Good job and a I like the no nonsense build thread.
    Jan 2018
    North Bay, California
    Looking good! I'm also running a T56 Mag and a Coyote! Great build so far! Love seeing all the progress! Hopefully I will be able to add some updates this weekend. Fingers crossed I'll have the engine in for the first (and hopefully last) time! Great build so far! Subscribed!
    Glendale Arizona
    HI Paul.
    The Gen3 Coupe when ordered with the that combo it is a bolt in solution. It still takes some planning, I drop in the engine only earlier this year to see where I can mount certain things, I have run my brake and fuel lines and most of my electrical. For instance the Relay /Fuse box for the Coyote is sitting on top of the footbox in some of my pics, that was so I could get the engine and trans in, the box is in it's permanent place bolted to the side of the foot box.
  7. #87
    Glendale Arizona
    Well we had our first start yesterday, not yet ready for go cart. Here are some pics
  8. Likes Straversi liked this post
  9. #88
    Gorham, ME
    Paul,
    You had a first start and all we get is a lousy picture?
    Congrats that's a big one!
  10. #89
    Glendale Arizona
    Just a quick update, We are in early go-cart stage, went up the street about 3 or 4 houses and turned and backed it in the garage. We was out at Barrett Jackson everyday and we had a little Pre Auction party, I do have some pics I hope to post soon.
  11. #90
    Glendale Arizona
    I've been working on a number of other projects and taking a little breather. I started to get back into the swing of things since the weather has been a bit cooler than normal. A couple weeks ago I was going to move it out of the garage and had no brake pedal, so I push it in and out. I got it up in the air and found I had a leaky brake caliper. Fix that re-bled the brake and I have good pedal now. I also know I was going to need a clutch pedal stop so the slave cylinder would not get pushed too far. Made one out of a Al barstock and appliance foot to make it adjustable. Also installed 1" wheel spacers in the rear that I purchased on Black Friday. We most of the little things done it was time for a drive around the block.
  12. #91
    Glendale Arizona
    Next on the list, passenger seat, finish off the upper hose, need a little rubber pad to keep it from rattling. AC plumbing, tools for that will be here on Monday. Body fitment and the start of body work. Here are some current pics
    Clutch pedal stop- Once I installed it and tested it, I was surprised how short the travel is, car starts clutch works as expected
    Some other pics
    Shift lever is temporary
  13. #92
    Gorham, ME
    Awesome Paul,
    Congrats on the first go kart. Are you doing the body work yourself?
  14. #93
    Junior Member johnny cobra's Avatar
    Feb 2019
    UK
    WOW just WOW this is such a great build ....... Great help to all Coupe builders ......Thank you ...
    I really fancy building a 65 Coupe ....
