Thread: Best starter for a 408 10:1 stroker??
    Mar 2018
    I went to start the car last night and I heard a loud clunk and a bunch of white smoke come up from under the hood. I'm thinking the only thing next can possibly be is the starter. My existing one is an 18 yr. old mini starter. Does flywheel teeth (157 vs. 164) make a difference in starter selection? I do have a 157 tooth flywheel. Thanks guys!--Mike
    Colorado Springs
    Go to Autozone or Advance and get a late model 5.0 starter. The solenoid is on the starter. It's a high torque mini-starter with a lifetime warranty.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Mar 2018
    Everything I read says to get an automatic starter because of the 157 tooth flywheel. Is this correct?
    Grand Rapids, MI
    I love my MSD Dynaforce starter. It’s tiny, indexable, looks great, and has absolutely no issue rolling over my 461w stroker. The down fall is it’s kinda pricy. But then it’s a great piece that looks and works like it costs $300.
    Senior Member Scott Zackowski's Avatar
    Oak Ridge, North Carolina
    Quote Originally Posted by Mjpesky View Post
    The starter must match your Flywheel teeth.
    Senior Member canuck1's Avatar
    Victoria, BC CANADA
    Quote Originally Posted by Bob Cowan View Post
    I agree, you won't need more than this. I don't know the full range of Mustang model years that work, but I can tell you for certain that the OEM Ford starter for a 94-95 Mustang GT is the PMGR (permanent magnet, gear reduction) starter you want. It will work with your 157 tooth flywheel.
    Sean
    MK 3.5 roadster (MK IV body retrofit to MK III chassis) 396W stroker, 4 bbl mass air EFI, QH (self-tuned), AFR 195CC Renegade, XE274HR, GP 4-1-4 SS headers, 3link, 3.73, 15" Halibrand replicas, SAI mod, bumpers, 2 X roll bars, I² electronics, PS, hydroboosted brakes: 95 GT front, custom MK VIII calipers/Cobra discs rear, FFR front, Levy rear LCA's, Forte front, VPM rear bars, CF dash, mod comp layout w/Auto Meter Ultra-Lites, Lucas tri-bar headlights, coupe taillights, painted by SRP (again!)
    Mar 2018
    Here is the one I ordered. Hope it's correct.
    https://www.walmart.com/ip/Discount-...rter/722301580
    Victoria, BC CANADA
    That looks like the right one, provided its designed for a Manual trans. Automatic has a different flexplate tooth count, I think.
    Sean
