![FormaCars](https://thefactoryfiveforum.com/attachment.php?attachmentid=62553&d=1483735916)
0
0
Pan Hard Bar Spec and engine/pinion angle?
When installing the 3-Link set-up and adjusting the pan hard bar, what is the proper off-set? I would assume at ride height you have some offset to account for the left and right travel of the axle when it rides up and down...
Second, what angle on your engine and pinion are good starting points?
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
