Results 1 to 5 of 5
Thread: Compressed air distribution setup
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I'm getting the shop set up in anticipation of my Mk4 roadster kit arriving in early January. I installed a 4 post lift a few months ago, and my new air compressor just arrived (5HP, 40 gal). The compressor is going to be intalled in a closet next to the garage, and I'll be running a 1/2" line to the garage (~25' run) and a 1" line to the basement workshop (~150' run) using RapidAir lines to have compressed air available in both areas. However, I'm a little overwhelmed by the number of choices and different ideas on filters, regulators, dryers, oilers and whatnot that everyone says are "must have's" for a compressed air distribution system. So, can someone please bring some sanity to my world and share some best practices? What do I need, and where do I need it? (next to compressor, at POU, etc.). I'll probably have a 50' hose reel in the garage that will be the primary source of air, and a wall-mounted quick-connect in the basement that I'll plug an air line into whenever I need air down there. Help!
    Sacramento CA
    I would try to plumb 2 or 3 drops in the garage maybe at the bench and at the garage door ( filling tires on vehicles outside) and then on the far side of the others. The last thing i want to do, is trying to drag an air hose from one side to the other.
    All the tire shops i have seen have a water trap on the bottom of the air drops, and a way to open them to drain the water out. They also plumb the small lines from the top of the main line to control the water.
    Also - using ball valves to shut off parts of the system
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Air System
    There's as many opinions on air system design as there are (fill in blank). Here are a few of mine... and some pics of my system (before the shop remodel, but it was retained)
    A flexible line and master shut-off between the tank and the "fixed" feeders is a must. Vibration will crack hardlines.
    My compressor builder included these pads. They're 1" cork, sandwiched in rubber. It "decouples" the compressor from the floor/bench. Again, vibration.
    My compressor is up on the workbench, in an unused corner. I remoted the tank drain petcock to where it's accessible and I can hang a bucket to catch the condensate.
    Just off the main feeder is a drop-leg with a ball valve. This is a condensate catch/drain.
    My supply lines run up high near the ceiling, with several drops around the shop. The drops are plumbed like this - up/over/down - again moisture control.
    I remoted the air intake(s) and filters up into the garage attic. No more "whumpawhumpawhumpa" in the shop. It's amazingly quiet now.
    Some better pics after remodel:
    A few other tips:
    - All horizontal runs should have a downward slope away from the compressor, about 1/4" per foot.
    - At the end of a main supply run, there should be a drop with a valve and drain.
    - Install shut-off valves on each main feeder, and at the inlet of the hose reel. Be able to isolate "legs" of the air system for repair.
    - Don't install a tool oiler anywhere on the supply lines! If you need to use one, plug it into the system at/near POU.
    - Buy some dedicated "dirty" hoses and "clean" hoses - Mark them. Only use the "dirty" hoses with a tool oiler.
    John D. - Minneapolis 'Burbs
    I have an automatic purge valve on my compressor that kicks off once per day to get rid of accumulated water in the tank. I also have a dryer and regulator plus a shutoff valve between the compressor and my primary hose reel. The compressor also has two hose connectors, one regulated and the other unregulated. I hardly ever use those. My shop has two rooms, and I have a drop on each. Also, I went through a couple of cheap hoses before finally getting some Flexzilla hoses. They are awesome!
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Senior Member TDSapp's Avatar
    Frisco, TX
    Everyone here has given some great input for a good garage air system. But if you are planning on doing any painting there may be a couple other things needed as well. I am not the one to tell you everything you need as I am still doing that research myself.
    I have been going over to the forums at https://www.autobody101.com and chatting with them about it. There are some very smart guys over there that seem to know everything about painting. They also have this page... https://www.autobody101.com/content/...ng-directions/ , which is an awesome resource on painting.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
