Results 1 to 12 of 12
Thread: Upgrading to a 427W...have some 302 parts for sale
    Senior Member Joe Campbell's Avatar
    Idaho Falls, ID
    I've stepped up to a 351-based motor, so I have these available from the 302:
    Kevko cobra kit car oil pan (single rear sump, 7.5in deep) and matching pickup, $200 shipped.
    Headers made by Stainless Headers, mild steel, ceramic coating, 3-in. header bolt spacing for aftermarket heads (no dimples in the tubes and easier to access. A little bit of oil got on one from a leaky valve cover, but can probably be buffed) One bung on each side for EFI. $400 shipped.
    302 Edelbrock Performer RPM Air Gap intake, $230 shipped.
    Attachment 83788Attachment 83787
    Idaho Falls, ID
    Updated.
    Kirkland, WA
    Joe, I have World 200 Heads, would these fit? as I'm trying to get rid of the J-Pipes.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Idaho Falls, ID
    Sorry I missed your message the other day, been trying to get the new motor going.
    If your heads have the dual bolt holes on each exhaust port, yes, they'll fit. I had them made to use the outer 3" spacing. Easier bolt access and don't have to pinch off the tubes for bolts on the inner spacing.
    Future Mk4 builder/owner
    Harleysville, pa (near Philly)
    Pm sent on kevko oil pan. Thanks.
    Idaho Falls, ID
    PmD you back
    Idaho Falls, ID
    Updated.
    bobl's Avatar
    Spicewood, Texas
    Couple of questions on the headers. What size are the tubes? They look like 1 3/4. I assume these are not stainless steel, correct? What heads were you running? Raised exhaust ports are standard? I'm currently running the FFR BBK headers and don't want to get into major alignment issues. My heads have the dual bolt pattern so going to a larger pipe diameter intrigues me.
    Idaho Falls, ID
    Sorry for the delay, been crazy at work lately. They are 1-3/4 tubes, carbon w/ ceramic coating. I was running RHS 200CC heads, 64cc chambers - standard height exhaust ports. Was just shy of 10:1 compression so I'm sure I was leaving power on the table.
    Idaho Falls, ID
    Also, open to partial or whole trades, looking for FFR manual rack, EPS parts, manual rack adapter.
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    Joe,
    Do you still have the
    MSD 8582 two-wire dizzy?
    I have a new manual rack that I picked up with a lot of other parts from someone. Interested in a trade?
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    615,215 miles as of 4/23/2022
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
    Idaho Falls, ID
    Updated prices and items. Thanks for the trade Ralph!
