Results 1 to 12 of 12
Thread: Do I need a clutch fork opening cover?
    Mark Eaton's Avatar
    Medford, Oregon
    Do I need to fabricate a cover for the opening in my Quick Time bell housing? Do any of the vendors sell an item like this? It seems like a large hole to collect road grime while driving...
    May 2016
    I didnt have one on my fox for decades, I dont have one on mine now. Love your 347 combo btw.
    Chino Valley, Arizona
    Ditto,
    Mark Eaton's Avatar
    Medford, Oregon
    Thanks guys
    Senior Member FLPBFoot's Avatar
    Cape Coral, FL
    Thanks Mark for asking the question. I was under my car last night and was thinking the same thing.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
    Feb 2018
    Frisco, TX
    From what I understand Quick Time designed it to not use a boot in order to mitigate heat.
    Thousands of miles driven with a QuickTime bell and no cover. Zero issues. While these get driven occasionally in rain (intentional or not) in general they don't see a harsh environment like DD's are designed and tested for. Nothing to worry about IMO.
    None on mine, no issues yet. Don't expect any; have hundreds of thousands of miles on cars without a boot on the fork.
    Kevin
    MKIV #8234
    I don't use one now, did on my first car for for about 1000 miles, till it wedged itself on the end of the clutch arm and the clutch wouldn't engage. Looking at your picture, I notice that the washers on the top bolt are installed out of order. The split lock washer should be under the head of the bolt, not a flat washer. Not a major issue.
    Rhode Island
    Rich grsc. A lock washer is intended to bite in to the under side of the head of the bolt and a stationary surface to help prevent the bolt from backing out, putting a flat washer between the lock washer and the stationary surface just lets the lock washer bite into the flat washer and the flat washer, lock washer and bolt then back out of the hole as a unit.
    You probably should have said, throw the flat washer away.
    BigUgly
    FFR 6760 Mk 3.1 Fortes Dart 427 TKO 600 3.55 3 Link Solid Axle
    Seasoned Citizen NAZ's Avatar
    No need for a cover on the QT clutch lever opening -- it's designed to be open. BTW, QT tests these to SFI test standards with that opening unobstructed and they must contain all the debris from a clutch explosion. If memory serves, they spin a 20lb flywheel at 10,000 RPM and fragment it at speed. Using a scatter shield like the QT pictured greatly enhances safety and is well worth the extra weight and $$.
    Mark Eaton's Avatar
    Medford, Oregon
    Rich grsc and Big Ugly, thanks for noticing, I'll get rid of the flat washer.
