Duff, thanks for the detailed reply. I will definitely use the info.Hey Plimpton I searched for a long time for wheels and tires, saved the ones I liked in my favorites and after saving the same ones several times that made the choise. They are Mickey Thompson Street Comp 245-45R17 and 315-35R17. Rims are American Racing AR105M 17x8--4.5 back space and AR105M 17 x 10.5 with 6.875 back spacing. The problem was the rears did not have enough back spacing, tire was way to close to the inner fender well, so I added a .875 wheel spacer to move them out. But in order to do that I had to go with longer wheel studs, which ment pulling the axles. I plan on running full fenders and I should move the rears out a little more to "fill" the fender opening but are reluctant to add more wheel spacer. At the present time I have 5" ride heigth rear and 4.75 in the front.
