![Very Cool Parts](https://thefactoryfiveforum.com/attachment.php?attachmentid=40527&d=1428867450)
0
0
Wiring LED Halo Lights
I need some help from all the electrical experts. I purchased replacement headlights with LED Halo lights. The headlights are plug and play. There are 2 integral Halo light strips with 4 wires (2 red & 2 black). The maker is United Pacific. I plan on running the Halo lights on a separate circuit with a switch so I could turn them on & off separately from the headlights. My question is what is the best way to wire up the Halo lights. I know that I can run a wire from the battery with fuse to the switch on the dash and then wire to each set of Halo lights with ground. Is that the best way or is a relay needed. That's where it gets dicey for me. I don't exactly understand the need and workings of a relay. If I need a relay, a wiring diagram would be useful. See pics below of the front and back of the headlight.IMG_2900 (1).JPGIMG_2901 (1).JPG
There should be no need for a relay due to the low current needed for the lights. You might reconsider taking power directly from the battery. Forgetting to turn of the lights might leave you with a dead battery
I just wired them to the daytime light circuit.
No need a for a relay with these LEDS. They probably only draw like 200ma each, total less than 1 amp. Make sure to wire each light set in parallel, not series.
I would find a power source that is hot with Key On, then install a switch off of that. Any Key On Hot circuit should already be protected by a fuse, but double check whatever circuit you choose.
Originally Posted by
Boydster
Thanks for the help. I just wasn't sure if I needed to use a relay. I will wire it up per your suggestion.
BobsMK4
Always better safe than sorry. Relays are typically used for a high amperage circuit, switched on by low voltage... hence the relay. As everyone before me said: Any circuit already fused should support it, but try to use something related to the Day Time Running lights, if you can.
You can connect the red wires together and connect to power. Same with black and then to a ground.
Have fun!
Gen3 Coupe - SOLD Arrival:
6/21/18 SOLD: 4/12/2019
@madd_wrapps on IG or
www.maddwrapps.com
I got those same lights and plan to have them "always on" serving as daytime running lights. They look great on the car, but I am in the middle of a major overhaul (to include wiring) so haven't wired up the LED ring portion yet.
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
