Thread: SpeedHut Gauges - Inverter for Dial Lights
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    I think I've got a DOA...
    Does anyone have the specs on the I/O voltage of one of these?
    I've got 13.7vdc on the input (wh & bk), but 0v AC or DC on the output (Bk/dots & BK). I've run the pot full swing and no change.
    John D. - Minneapolis 'Burbs
    Contact Speedhut for a replacement. Unfortunately they are often DOA...I think it took 3 tried to get a working one on one car I built.
    Chino Valley, Arizona
    Apparently according to them, this used to be an issue which they resolved with a new module. I replaced mine within the past year and the newer one appeared different. Speedhut has tremendous customer service and will ship you out a new one.
    Jax Beach, FL
    Output is 200VAC if I remember correctly.
    You remember correctly. https://faq.speedhut.com/kb/gauge-li...ng-system-work
    Aug 2017
    Minneapolis 'Burbs
    Received a replacement inverter the other day, plugged it in, and voila! Dash lights.
    Took nothing more than an email to SpeedHut explaining the situation and they sent one out.
