11-15-2018, 02:25 PM
#361
I have more parts and need to get to work, but it is soo smoky from the camp fire north of us that it is hard to go outside. I am sad for all the people in the fire it was so fast & hot. We have been in two floods and it takes a long time to get life back together!IMG_8256.JPGIMG_8257.JPGIMG_8260.JPGIMG_8262.JPG
The heat exchanger will go in trunk, air to water coolers will go under front fenders.
11-15-2018, 02:41 PM
#362
Nice. Having an ice chest in the trunk will keep those 33" Goodyear's hooked!! Which Garrets did you go with??
11-15-2018, 03:04 PM
#363
New garrett G25-550, twins. Setting up for 1000 HP if i want to run methanol at some time, but will set for pump gas as this is a driver.
11-24-2018, 02:27 PM
#364
Takes a lot of work to make custom headers, but one is all most done.IMG_8263.JPGIMG_8264.JPGIMG_8267.JPGIMG_8268.JPGIMG_8269.JPG
11-24-2018, 09:55 PM
#365
My shoulder hurts just looking at those pics! The last set I did was quite awhile back. I chamfered the head side of the flange and swaged the tube into the chamfer to weld it and ground it flush. Never cracked or warped.
11-25-2018, 03:39 AM
#366
I like the framing you did to your running boards no you can stand on them. I was thinking of doing the same thing because if you dont and someone steps on them they will crack. Good Job.
12-04-2018, 08:25 PM
#367
One side on to make sher things fit. Need to do a little work on other side.IMG_8270.JPGIMG_8271.JPGIMG_8273.JPGIMG_8274.JPG
wrp thanked for this post
wrp liked this post
12-04-2018, 09:34 PM
#368
That is really looking awesome.
12-07-2018, 02:42 PM
#369
PS header done, had to make it tighter for ac & heater hoses.IMG_8276.JPGIMG_8278.JPG
Not perfect but i think they will do the job!
Will not done, need to put in wastegate pipe.
12-08-2018, 01:23 AM
#370
Worked on down pipe and was able to make them out of a 180, but did not have the right size pipe to work on wastegate.IMG_8282.JPGIMG_8283.JPG
12-08-2018, 09:49 AM
#371
Few can probably appreciate the effort you are putting in to this. Constructing your own headers is nothing short of badass. are you going to clock the output/cold side outlet and run it inside the engine compartment or are you going to run it straight to the intake/intercooler?
12-08-2018, 01:14 PM
#372
It will go down inside fender to air to water cooler then back into front of engine- we will see about how this go's !!
wrp liked this post
12-08-2018, 10:51 PM
#373
Where will the BOV be? Consider a Leash Boost Controller
12-09-2018, 09:30 PM
#374
Need to ask tuner about BOV placement, but in piping after tubes come together and be for intake.
At this time going with standard BOV.
12-09-2018, 11:17 PM
#375
Just thinking outloud, would be cool to have Turbo reversed so Downpipe is exiting rearward as a side pipe. That would bring the cold side to the front, out of the path of the heat. What you are doing is really exciting.
12-10-2018, 12:17 AM
#376
I am trying to keep it clean as possible, with full fenders and running boards it is a challenge!! No room and no room. Water to air coolers in side front fenders with heat exchanger and AC condenser
in the trunk, plus two not yet made fuel tanks under the top tank for more gas (we will not talk mileage) and to have weight lower.
Putting another 1&5/8 DOM safety tube from front to back of roll cage along seats.
12-10-2018, 05:53 PM
#377
Talked to tuner and BOVs will be at turbos. So will have all the goodes in one place.
wrp liked this post
12-12-2018, 02:08 AM
#378
Will it takes time to get the wastegate on, one of two done, now for the pipe to exhaustIMG_8287.JPGIMG_8291.JPG.
12-12-2018, 10:31 AM
#379
Tom, Great packaging work! You may be inspiring some future turbo builds. I've been eyeballing those barrel style water to air intercoolers myself for a different project. You're going to have a fun ride next summer!
12-17-2018, 02:41 AM
#380
Got wastegate pipes done, not easy to get all three vband joints to line up. Looking on how much to cut out of side panel.IMG_8293.JPGIMG_8300.JPGIMG_8301.JPGIMG_8299.JPG
wrp liked this post
12-17-2018, 06:26 PM
#381
12-18-2018, 02:09 AM
#382
Got the turbo oil drain lines made and on, then worked on ruff cutting side panels.IMG_8302.JPGIMG_8303.JPGIMG_8308.JPGIMG_8309.JPG
Post Thanks / Like - 1 Thanks, 2 Likes
12-20-2018, 02:45 AM
#383
12-25-2018, 02:05 AM
#384
12-26-2018, 11:35 AM
#385
12-27-2018, 03:14 AM
#386
Made my two to one intake with air straightener. Had to expand the tube (3 1/2 od and 31/2 id air straightener)to fit.IMG_8336.JPGIMG_8337.JPGIMG_8331.JPGIMG_8332.JPGIMG_8338.JPGIMG_8343.JPG
wrp liked this post
12-30-2018, 02:05 AM
#387
Pipes are almost done, need to build the MAF bracket yet. Then work on exhaust, take it apart and put back together for i hope the last time.IMG_8349.JPGIMG_8350.JPGIMG_8351.JPGIMG_8355.JPGIMG_8360.JPG
12-30-2018, 01:21 PM
#388
So you are going to run a MAF? Do they have Speed Density Tuning for Fords?
12-30-2018, 05:09 PM
#389
This is the way my tuner has me set it up, MAF goes within 4 inches of air straightener. will put at 2 inches.
I am working with [email protected].
12-31-2018, 09:52 PM
#390
I ran speed density tune, eliminating math, a little more difficult to tune precisely. I did not know if Fords had that option.
01-01-2019, 01:30 PM
#391
The tuning is over my head. I trust SHAUN@ AED and went with parts he works with!
Think i will go with cortex EBC boost controller, like the boost by gear and overall protection.
wrp liked this post
01-06-2019, 04:51 PM
#392
Lost my camra card so no pics. Have turbo piping done, now under car exhaust and( Race Mufflers) waiting on them . Fixed radiator moved inlet to off center a long time back had some pinholes from using wire welder, now have tig so weld and grind till i got the garbage out. Did some mods to the finder brace to get rid of nuts on inside., Made oil drain on oil filter( filter on top) to take oil to under car, no more oil on everything to change filter! Still don't know how i will finish the grill.
wrp liked this post
01-10-2019, 11:59 PM
#393
Looking to put air scop or other intake behind doors in front of rear fenders. My heat exchanger and AC condenser are in trunk with fans but need air entrance and some forced air.
Have not found any that will work, so will maybe make them. Any ideas?
wrp liked this post
01-27-2019, 11:11 PM
#394
Got moved out of house so they can do the remodel (been there and done that) let others do it. So i can go back to working on car, but my computer is dead, so no pics till new one.
02-01-2019, 02:15 AM
#395
Built a tube for lower radiator hose DPP_0001.JPGDPP_0001.JPGDPP_0002.JPG Haft to take left shock off and it goes in from bottom, two short hose's
02-04-2019, 01:50 AM
#396
Had to rework finder brace(had shim in) to get it all good. So got it put together and finders even and ruff fitting of turbo pipes.
Don't think it will stay together, it has to come all apart!IMG_8376.JPGIMG_8382.JPGIMG_8377.JPG
02-04-2019, 11:01 AM
#397
Consummate Learner
That's going to look awesome!
02-04-2019, 09:56 PM
#398
This is how it will look, needed the room on bottom end of BOV to get put together. may make aluminum band to go around outside of cutout's.IMG_8383.JPGIMG_8384.JPGIMG_8385.JPG
wrp liked this post
02-16-2019, 11:29 PM
#399
Working on exhaust, three inch round to oval. Will exit in front of rear wheels.IMG_8387.JPGIMG_8389.JPG
Most of hoses and wires tied down, going from front to back.
wrp liked this post
02-19-2019, 10:07 PM
#400
This is the 3 inch pipe from flex to muffler on left sideIMG_8390.JPGIMG_8391.JPG
goes inside frame.
