Results 1 to 11 of 11
Thread: Roadster hood hinge
    Accord NY
    Roadster hood hinge
    When putting together the hood hinge should the stainless washer fit over the shoulder of the shoulder bolt or but up against it? Mine buts up against it so you can’t tighten the bolt any further. Is that the way it’s suppose to be or do i need larger washers to go over the shoulder?
    Craig
    Nov 2016
    Petaluma, CA
    I found that the hinges were far too "sloppy" when I did them like that. I got other washers and tightened them against the spring washer using a nyloc nut so I could adjust the tension. Joel
    This! ^^^
    BadAsp427's Avatar
    Greeneville, TN
    I did the same. Really made it snug and smooth. Also put a dab of white grease on them.
    Accord NY
    Thanks everyone.
    5/16 cut washers have a 3/8 hole . Easiest is to put two washers on the bolt first, through the brackets and bushing with one more washer on the backside then nut. Tried to use the wave washers once.....that was enough. ..da bat
    Accord NY
    Hi Jeff, The washers I got with the kit don't fit over the shoulder of the bolt. You are putting two washers on the bolt and then putting it through the hole, correct? Japollon suggest I put them o the other end. I assume it doesn't matter as long as you tighten up the slack.
  8. Likes hugo-k liked this post
    I was giving you the easiest way. You may have to buy a few washers. You have some in your kit but they are for general use. The 5/16 cut washer slips over the shank. The reason I say to use two is so once installed the other end of the shoulder bolt isn't peeking through the hole causing you to try to center a washer so you can take up the slack. I tighten mine tight the back them off until I can turn the bolt with just a little friction. It takes the slop out of the hinges. You have 8 hinge joints.....little bit oy play in each + a whole lot of wigglin around...da Bat If it is still a little unclear my # 951-676-0191
  10. Thanks WIS89 thanked for this post
  11. #9
    Accord NY
    Appreciate the offer but I got it from here.
    Thank you
  12. #10
    I've been using these thick fender washers from my local "if they don't have it nobody does" hardware store.
    Nice because you use just one per bolt so you don't have to deal with stacking washers and trying to keep them properly aligned. Like Miller I chuck the wave washers.
    So. Bay (So. Calif.)
    Quote Originally Posted by cfriedman67 View Post
    Ah... Man... How many times have I said that one.
