This asymmetry really tricked me, have to redo some things on the passenger side of the body now...I had no idea that the driver's side door sculpting was close to 20mm wider!
I'm going to redo the gas tank filler, the GTM "makes do" with the crossover fitting on the tank, and I have concerns about venting and fill rates. Will fill gas from the driver's side only. Ordered some hdpe barb fittings from 123ponds, 1.5" to fit the fill tube on the C5 fuel filler neck, and 5/8" barb fittings for venting the driver and passenger tanks back to the C5 fuel filler neck vent. Will plastic weld the fittings to the tops of the tanks. Ordered a variety to play with. About $2 each.
Will move the fuel filler up to the 1/4 window area, kind of like the 918.
