Thanks Thanks:  3
Results 1 to 5 of 5
Thread: Cobra front brakes?
    Nov 2018
    Cobra front brakes?
    Can I bolt on 1994-2004 Cobra front rotors (13") and calipers? I'm concerned that I have the 13" on the rear (IRS) and only 11" on the front.
    Maricopa AZ
    Yes you can.
  3. Thanks GBPCAZ thanked for this post
    Senior Member Clover's Avatar
    Colorado
    Can you just bolt those on in place of the kit's included calipers and rotors or will you need some brackets as well? Seems like it may be a cheap option that may be a bit better paired to the rear IRS set up.
    Gen III Type 65 Coupe Delivered 6/26/2018
    Nov 2018
    That's what I was thinking. Thanks
    Prairieville, Louisiana
    Anything that is supposed to be a direct swap out for 2004 Mustang should be a direct swap out for your front brakes.
  7. Thanks GoDadGo, GBPCAZ thanked for this post
