Results 1 to 4 of 4
Thread: Recommended routing of Forte clutch hose
    Apr 2018
    Colgate, WI
    I received my master cylinder from Mike for the hydraulic clutch. Hose seems relatively short, requiring some fairly optimal routing. Anyone have pictures of how they routed theirs? Thanks.
    Mk4, IRS, (Forte: 427 with EFI, T-56 MAG, hydraulic clutch, mechanical linkage, reverse lockout control module) (Breeze: Front and Rear Double adjustable QA1's, Cockpit cubby, LED Lights, Fan Shroud, Fan Lower Support, Oil Cooler Coil, power steering hose kit) (Russ: Drop Trunk, Turn Signal)
    Fairfax Station VA
    I used a 90* fitting out of the master, ran the hose along the 2" frame (secured it there with a rubberized R clamp), then punched through the foot box side under the mechanical linkage (grommet on the hole). From there it just drops down to the slave.
    IMG_2756 by jhsitton, on Flickr
    MK IV Roadster #8631
    Similar routing here. Out of the MC, along the 2-inch tube, then out the footbox wall down to the slave. I use same hole in the footbox side as typically used to bring the rear harness into the cockpit. The alignment is just right.
    Apr 2018
    Colgate, WI
    Perfect, thanks guys!
