I received my master cylinder from Mike for the hydraulic clutch. Hose seems relatively short, requiring some fairly optimal routing. Anyone have pictures of how they routed theirs? Thanks.
Mk4, IRS, (Forte: 427 with EFI, T-56 MAG, hydraulic clutch, mechanical linkage, reverse lockout control module) (Breeze: Front and Rear Double adjustable QA1's, Cockpit cubby, LED Lights, Fan Shroud, Fan Lower Support, Oil Cooler Coil, power steering hose kit) (Russ: Drop Trunk, Turn Signal)
MK IV Roadster #8631
Similar routing here. Out of the MC, along the 2-inch tube, then out the footbox wall down to the slave. I use same hole in the footbox side as typically used to bring the rear harness into the cockpit. The alignment is just right.
