I'm looking for some close up pictures of the e-brake boot and options for mounting it to the transmission tunnel. I guess sheet metal screws will work but is that the best way? Help!
Thanks, Joel
Thanks, Joel
Sheet metal screws will work fine. I used black colored screws, with finishing rings to match the boot. They have remained solid since day one.
I think its replicarparts that has a nice Crome trim ring to fit around it and finish it off.
Thanks to all for the responses. Joel
