0
0
shifter linkage bushings
the bushings in the pics for the shifter rod keep coming out of place. when that happens it allows too much play and it is hard to get into gear. any idea what is suppose to keep them in place?
as you can see the bushings on both sides keep coming out.
thanks
I would try some green Loctite bushing dressing.
thanks i have heard of loctite red and blue but not green. i will have to see if my local auto parts store carries that.
