Results 1 to 6 of 6
Thread: Coyote Oil Filter question
    Lake Mills, WI
    Hello all
    Please see these photos: Will this filter come off the motor?
    5.0 Gen 2 Coyote with Wix filter.
    I just installed the motor into the chassis and its filled with oil
    This looks very tight-I'm guessing it will just make it.
    Please let me know
    Martin
    Really easy to know, just unscrew it and find out.
    Lake Mills, WI
    Yeah
    I really didn't want to drain the oil again....
    M
    You will not loose that much oil. Screw it off, see if it will clear the frame, screw back on. You can wipe off the filter while it is off.
    On a roll Al_C's Avatar
    Wheaton, IL
    It fits. I have the same filter. I put it on with the engine installed. You have to do it from underneath, but everything works as it should. At least in my experience. I had to include the disclaimer lest somebody else come up with a different experience
    Senior Member frankb's Avatar
    Feb 2014
    Marana, AZ
    I have about the same clearance between my filter and the frame on 8317. It'll come off, but it is close.
