Results 1 to 3 of 3
Thread: SBF water line routing
    Jun 2018
    North Vancouver, BC, Canada
    I'm sure most of you guys know this stuff since you were 2 years old. Want to make sure I understand where all the water cooling lines get connected on my 347 and where the temp gauge sensor goes.
    The 2 radiator connections are obvious. But the rest was a bit of a head scratcher. I've tried to indicate where I think things go on the following picture.
    Am I close?
    Rotonda West Florida
    Looks good to me. The Red line will have a thermostat housing with a hose nipple. YOu will need a visit to the local parts store for a ford 302 bypass hose. About 8 bucks. Don't use regular hose it will collapse. A molded piece is required. Since the thermostat housing is going to vary by your selection, expect to trim the hose to fit.
  3. Thanks FF33rod thanked for this post
    Jun 2018
    Excellent, thanks for the help.
