Likes Likes:  2
Results 1 to 9 of 9
Thread: Lower Door Hinge Marking
    Senior Member TDSapp's Avatar
    Frisco, TX
    Is it just me or does the manual only how to mark the upper door hinge? I marked the upper ones today but there is no way to get the ruler down and across the body\jam.
    Is there some special way to do this?
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    There are a couple of video out there. Check this video from the Compound YouTube site. Some of the language is adult rated, so you may not want the kids around. I wish I had seen this video before I hacked into my body and doors. https://www.youtube.com/watch?v=Qled...h2ihO&index=21. Good luck.
    This is a 6 part series that has some good information as well https://www.youtube.com/watch?v=jOzxgY01t9k
    Placitas, NM
    If you think the lower hole is a pain wait until you get to trimming the door to fit, the door bracket frame, and the claw lock.
    Put some super glue on the brass bushings for the hinges so the bottom ones don't fall out 10 times.
  5. Likes FF33rod liked this post
    Apr 2014
    Memphis, TN
    I followed the compound video, and the Eric Hansen videos. They walk through it pretty well and it made sense to my mind.
    Ryan
    33 Hot Rod
    Frisco, TX
    Great idea... I discovered yesterday that one side had to be hammered in, the other would just fall out. Of course the one that falls out faces the bottom.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Frisco, TX
    Quote Originally Posted by wrp View Post
    Thanks Bill, I watched these again yesterday and they helped a bunch. When I saw how he move the marks to the outside I was like Duh!
    These are the first hole I have cut into the body...
    As you can see from the last photo I have marked the lower spots as well. But I wanted to check a couple things before I started cutting them out.
    And before anyone ask Yes, I did have protection on before cutting the holes.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Apr 2014
    Memphis, TN
    Tim,
    The other advice I have, and I think it was in one of the videos. Start on the passenger side, you will do the job far better the second time (drivers side) and it will get used by you far more often.
    Ryan
    33 Hot Rod
  10. Likes AJT '33 liked this post
  11. #9
    LoL I got some resin and fiberglass clothe left over when you are ready
    Glass-114.jpgGlass-122.jpgGlass-123.jpgGlass-129.jpgGlass-133.jpgGlass-137.jpgGlass-142.jpgGlass-148.jpg
