I purchased the Factory Five EFI in tank fuel pump. It comes with flexible fuel lines which the instructions say to route to the engine bay through the drive train tunnel. I always thought that routing fuel lines through the drive train tunnel was something you should never do because of the fire risk from a broken drive shaft, etc. Is this no longer a concern? Are those of you that have this set-up running them through the tunnel? If not, what are you doing?
