Thanks Thanks:  5
Thread: Belleville washer thickness?
    FF6602's Avatar
    Nov 2018
    State College, PA
    The Belleville spring washers (.50 OD / .255 ID) that go on the upper steering shaft are missing from the pieces I got with my unfinished kit. I found them on the McMaster-Carr website (thanks to edwardb for sending me there) but there are four thicknesses listed. The choices are:
    0.018
    0.022
    0.025
    0.038
    Because this is a "spring washer", I assume the thickness (height) makes a difference. What's the correct thickness to use?
    Craig
    10/2018 -- acquired Mk3.1 #6602 which was an unfinished project in go-kart stage; 9/2019 -- completed car enough to drive locally and compete in autocross events; still in original black gel-coat; 347 Stroker w/ Holley 650 carb, roller cam; Tremec 3550; 3.51 rear diff; lots of Breeze pieces; 2021 -- XP Champion in Central PA Region - SCCA Autocross Series; 2022 - installed windshield and registered in PA; my Build Thread -- https://thefactoryfiveforum.com/show...ished-Business
    6/2022 -- acquired Mk3 #1004; finished build; 347 stroker w/ Holley 560 carb SOLD
    Call Factory Five, they will mail you the correct ones.
  3. Thanks FF6602 thanked for this post
    Senior Member Scott Zackowski's Avatar
    Oak Ridge, North Carolina
    Quote Originally Posted by FF6602 View Post
    0.018
    0.022
    0.025
    0.038
    Edward will hopefully chime in.
    If I recall his discussion on this in the past, you can adjust the thickness to help take up slack/play in the column/shaft.
    But I am not sure of the FFR original part thickness.
  5. Thanks FF6602 thanked for this post
  6. #4
    Base to crown measures .034.
  7. Thanks FF6602 thanked for this post
  8. #5
    Based on my research and measuring a couple builds ago, FFR supplied Belleville spring washers are equivalent to McMaster #9712K62. https://www.mcmaster.com/9712k62. I used the next higher size #9712K63 (.038 vs .036 total thickness) and improved the fit of the collapsing column on that build. The most recent build (Gen 3 Coupe #59) use the provided washers from FFR and they worked perfectly.
  9. Thanks FF6602 thanked for this post
  10. #6
    Raleigh NC, OIB NC
    +1 on the McMaster thicker washers.
    Kevin
    MKIV #8234
  11. Thanks FF6602 thanked for this post
  12. #7
    Manchester, MD
    PM me with your address and I'll send some to you. Got a bunch from McMaster.
