IRS Sway Bar Mounts - 2015 style
Any have a set or most importantly the passenger side sway bar mount? This is angled steel piece that mounts to the diff/suspension and then holds the sway bar parallel to ground. I might consider a complete rear sway bar assembly.
I had both mounts but misplaced the passenger side.
Parts are for the 2015 IRS.
Jim
