Results 1 to 11 of 11
Thread: hard line to hose adaptor
    Jun 2018
    North Vancouver, BC, Canada
    The simplest things sometimes seem the hardest. I have 3/8" steel line for fuel. It has the standard inverted flare end with captive male fitting. I want to mate with a 3/8 i.d. hose so I've been looking for a female flare to hose barb adaptor. What would you use? Closest I've come is Parker 128HBLSV-6-6
    http://ph.parker.com/us/27601/en/bra...s/128hblsv-6-6
    What would you use?
    Thanks for the help
    Port Charlotte, FL
    Steve,
    I would give Mark at Breeze Automotive a call. He has what you need and he is a vendor here.
    Thx,
    Henry
    Steve-
    Henry's right, as usual!
    Here's a link to what I think you want. Mark is a great guy to work with, has great products, and his service is second to none.
    https://www.breezeautomotive.com/sho...ainless-steel/
    I hope this helps.
    Jun 2018
    Thanks guys, that helps a bit. I wasn't planning on adapting to an AN fitting. Was just going to go from the 10u filter after the pump with a 3/8 hose and clamp both ends. In general, is there a "go to" vendor for all these fittings? I see a few on summit, a few on Amazon, Russell, .... doesn't seem to be one place to get everything.
    Mar 2013
    Medway, MA
    You could cut off the inverted flare end, install the 21608 and use this fitting in the end of the hose:
    https://www.breezeautomotive.com/sho...o-06an-female/
  6. Thanks FF33rod thanked for this post
    Maybe one of the above will work
