Likes Likes:  3
Thread: Grill from Breeze test fit
    Senior Member DavidW's Avatar
    Stevensville, MD
    I just got my Breeze grill back from the powder coater, I got it anodized so it wouldn't corrode over time. The anodizing made it a little darker gray than the original silver aluminum color it was when I got it from breeze.
    I think I'll install it with silicon or maybe automotive goop, any suggestions ??
  2. Likes Ducky2009, John T liked this post
    cv2065's Avatar
    Dec 2017
    I really like the look. Very finished. Might have to pick me one up!
    Heart of Dixie, Alabama
    Grills looks super. I do not have them in my plans, but after seeing yours, that is probably going to change. Just when I think I have settled on a color, you put that show stopper in my face. I am hoping you will give the color codes on both the body and stripe. I think all the post it notes on colors will get pulled down. I am impressed! Can you tell.
    Every time I see that gray, I am stoked at how good it looks. And I dig the Breeze grill.
    Stevensville, MD
    Thanks. Here are the colors;
    Paint , Ford , Ditzer PPG, RM BASF
    Body – Sterling Gray Metallic, M7205, 919055, 765145
    Stripes – Rubi Red Metallic, M7283 , 931662 , 883552
    Stripes outline – Tuxedo Black Metallic, M7211, 918644, 765124
  7. Thanks Railroad thanked for this post
  8. #6
    Stevensville, MD
    Thanks, Ive been going back and forth, I really like the one Jazzman has on the flip top build but this will do. There is one for sale in the Part page on this forum.
  9. #7
    Stevensville, MD
    Quote Originally Posted by Boydster View Post
    Shouldn't be long for you now, just in time for good weather.
  10. Likes Boydster liked this post
  11. #8
    Copperhill, TN
    I used strips of heavy duty exterior mounting tape so that I could remove it if needed (which I did need to to pull the radiator). I spent some time treaking the bend on the flange so that it laid flat on the body.
    Looks great by the way.
  12. #9
    RJD's Avatar
    Northern Virginia
    Beautiful! Grill is a must have now.
