Results 1 to 3 of 3
Thread: Paint & Body Shop In Houston.
    Houston
    Any recommendations?
    Also, I'd like to know what a realistic cost is for a "regular" paint job the Coupe. Any info on the split between body-prep and actual painting would be interesting.
    fred
    Oct 2018
    ada minnesota
    paint time with last sanding would proabbly be 5 to 10 h
    ours
    body prep time on a truck 40 to 100 hours ?? I have had a few chunks of gel coat fly off from blow gun
    I am far from a expert, but I did run my shop as a body shop for 18 years
    body work as a hobiest seems beter, actually took the day off and I enjoyed it !!!!
    Houston
    Quote Originally Posted by Houdini View Post
    ours
    Thank you very much. That helps me a lot to figure out what my realistic expectations should be. Finding what a typical hourly rate is around here should be no problem.
    Much appreciated.
    fred
