Results 1 to 5 of 5
Thread: Wrong door frame?
    Wrong door frame?
    Working on installing my door card. Cut out for the handle, but there is no frame member to attach to, it’s higher than the cut out. Looking at the manual different pages show 2 different types of frames for the door. How have others done it?D75651C5-FC06-4E44-8AF3-D43F607B875C.jpg
    Sep 2015
    Hamersville, Ohio
    I made a sheet metal bracket to mount my inner door handle. Just bolted it to the framework with riv nuts. Make your cutout big enuf to allow the handle escutcheon to snap into place but be careful, the margin of error is small. Cut/grind a little, then check fit, continue until escutcheon clips pass thru door card.
    Leesburg, VA
    I bolted the handle to an aluminum plate that was attached with standoffs to the door frame. If I recall, the standoffs were slightly different lengths between the two doors - you have to size them to fit.
    Sep 2015
    Hamersville, Ohio
    Of the two different door frames, one would be for a roadster, the other for the coupe. Not sure what images were used in the manual. The coupe frame has provisions for the window & regulator mechanisms. That's another story alltogether.
    Looks like I got sent the coupe doors2C78E42B-6F90-4EAD-B625-1B089F220F39.jpeg. Looking at the manual, both types of door frames are featured in the pictures. Bummer, spent so much time getting the driver door aligned with paint stick gaps and the door not scraping on the body, to have to take it off again to fabricate a part to connect the door handle to.
