Results 1 to 15 of 15
Thread: A/C Compressor oil
    Senior Member Kempo's Avatar
    Cabo Rojo,PR. USA
    A/C Compressor oil
    Hi guys,
    Need some help here. I got a new Delphi A/C compressor for my build. I forgot to check for oil before installing it. Any of you guys know if they come with oil on them or not?
    GenII GTM #354
    Delivered (02/09/11)
    Member claybags's Avatar
    rio rico,az
    Some do, some don't!!! Ask me how I know!! Mine didn't which, like you, I discovered AFTER the engine was in. I removed the header, undid the comp. mtg bolts, pulled the comp out from the mounts so I had access to the fill plug. Made up a dipstick and checked for oil. DRY!!! rigged up some tubing and a funnel, and filled it with the correct amt. of oil plus leak-check dye, re-assembled. A real PITA!!! Kicked myself for forgetting to check it after it arrived, so much easier to do on the bench.
    HTH.
    Cheers, Jeff
    PS...Don't know why SSP is such a PITA to deal with, they're getting a really bad rep.
    GTM 422, LS6, cam, heads, Mendeola trans
    Cabo Rojo,PR. USA
    [QUOTE=claybags;36303]Some do, some don't!!! Ask me how I know!! Mine didn't which, like you, I discovered AFTER the engine was in. I removed the header, undid the comp. mtg bolts, pulled the comp out from the mounts so I had access to the fill plug. Made up a dipstick and checked for oil. DRY!!! rigged up some tubing and a funnel, and filled it with the correct amt. of oil plus leak-check dye, re-assembled. A real PITA!!! Kicked myself for forgetting to check it after it arrived, so much easier to do on the bench.
    HTH.
    Cheers, Jeff
    PS...Don't know why SSP is such a PITA to deal with, they're getting a really bad rep.[/QUOTE
    Thanks for the reply Jeff. Just got and email from the place I ordered it and he confirmed that mine comes dry.
    About SSP, over the phone Steve sounds like a real pleasure to do business with. Very accommodating to any custom requests on the harnesses but in the end there was always a new excuse for not being done with it. I did have a horrible experience with them. Did you order something from them?
    GenII GTM #354
    rio rico,az
    Yeah, I got a semi custon engine harness plus a re-man ECM. Took a while, but I am in AZ . Harness was very nice, ECM..well, kept getting a code that my 4 wheel dr P/N was screwed up, so I don't know what it was out of. Then started hearing stuff about him among the local tuners, so I went somewhere else. Too bad.
    Hey, I was anchored out in the bay there a few years ago, I shoulda' looked you up had I known LOL.
    Cheers, Jeff
    Cabo Rojo,PR. USA
    Quote Originally Posted by claybags View Post
    Cheers, Jeff
    Where at San Juan or here at Cabo Rojo? If you ever make it back down here shoot me a PM.
    GenII GTM #354
    rio rico,az
    Cabo Rojo. Hung out for a few days before crossing the Mona Passage to the DR. Fun time!!
    Cheers, Jeff
    rio rico,az
    More precisely...Boqueron
    Cabo Rojo,PR. USA
    I live about ten minutes away from Boqueron. Are you one of those guys that come all the way from the states on a sail boat? Did you by any chance stopped at Mona island on your way to the DR? I'm glad you had a fun time here.
    GenII GTM #354
    rio rico,az
    Well, we were on our way to Florida from the Meditteranean after spending 4 years in Europe. Now with a GTM, I fear my sailing days are at an end! LOL
    Cheers, Jeff
    Cabo Rojo,PR. USA
    Cheers, Jeff
    That is one LOOOOOOOOOOOONG sailing trip.
    GenII GTM #354
    Cabo Rojo,PR. USA
    I removed the compressor last night and took it to the shop of a friend to add the required amount of oil. I always like to see the positive side of things, even in situations like this one where I forgot to add the oil before the install. I had to pull the compressor to add the oil but the good thing was that I was able to read the serial number of the engine which is hidden behind the compressor. I will need that number when the time to register the car arrives. I was also able to solve another problem I had. The connector on the compressor is located at about 8 o'clock on the stock C5 compressor. This created a clearance issue with the chassis. As soon as the engine would have moved on hard acceleration or deceleration it would have broken that connector from the compressor clutch. I had even marked the chassis to modify it to gain some clearance. After pulling the compressor I noticed that there is another notch at about 2 o'clock on it that can accommodate the clutch connector. So, I asked my friend to pull out the clutch and relocate the connector in that notch. No more clearance issue there.
    Before
    After relocating the connector
    GenII GTM #354
    Charlotte, NC
    That's where it is... I knew that I had seen it. The person that I spoke to said that it was on the front of the block on the passenger side, just below the head. I understood that to mean somewhere around the water pump. But then I vaguely remembered seeing a lazer etched serial number on the side of the block, but couldn't remember where.
    That will sure help some other people here! Thanks for posting this!
    The Stig
    GTM #0081
    Senior Member Joe Mush's Avatar
    Canton, MA
    Kempo, How much A/C Compressor oil did you add ?
    Joe
    Cabo Rojo,PR. USA
    Joe,
    7 oz were addded to the compressor. There will be another 3 that will be added with the refrigerant.
    GenII GTM #354
    Canton, MA
    Thanks Kempo
