Results 1 to 16 of 16
Thread: Gaskets or RTV on Exhaust Headers
    Senior Member Todd Buttrick's Avatar
    What are people using on exhaust headers between head and headers? I have the FelPro 1415 gaskets for my AFR 185 head exhaust side. The port matching is good for the head side but the four into 4 header side is pretty poor. Thinking I might just use Copper RTV and no gasket. What say the jury?
    Colorado Springs
    The port match is pretty bad. I haven't used a gasket in years, only high temp silicone.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Jun 2018
    North Vancouver, BC, Canada
    Gasket, no RTV.
    Sreve
    Senior Member frankb's Avatar
    Feb 2014
    Marana, AZ
    Because my engine needed custom header flanges, I use this stuff- https://www.summitracing.com/parts/php-67006/overview/ and cut my own gaskets. The headers have been off and on twice and no leaks!
    Mark Eaton's Avatar
    Medford, Oregon
    I used copper RTV with the gasket
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    I blew out one of the provided gaskets after only a handfull of miles.
    Decided to give (Remflex 3028 Exhaust Gasket for Ford V8 Engine) a try after reading lots of mustang guys liking them.
    Not enough miles (2k) to know if they'll stand the test of time, but so far so good.
    LOL. There were four possible answers to this question and I got all four in the first four posts. . I’m going with Bob on this one for ease of installation. I guess a fifth answer is to use nothing at all.
    Copper RTV, every gasket I've used eventually failed.
  9. Thanks Derald Rice thanked for this post
  10. #9
    So. Bay (So. Calif.)
    I also have a header flange to head port mismatch. On the advice of Bob (above), I did just the Copper RTV and NO gasket. I have 800 miles since that install 2 years ago. No problems so far. On a side note, I used the 4 into 4 gasket for the side pipes (cut out the little star in the middle) and no RTV. Again, so far no leaks.
  11. #10
    Aptos, CA
    Percy's. Stage 8 bolts. No issues in 17+ years. No leaks, and, they can be reused.
    www.weendoggy.com/cobra.htm
  12. #11
    I quit using header gaskets years ago. One warning, make sure your flanges are actually flat. Mine needed some work. I used a large flat file moving diagonally so I got marks on the high spots. Then a powered sander to work the spots down. Then back to the file diagonally in the opposite direction from before. A few cycles later they were flat. On mine the ports are a bit smaller than the holes in the flange but offset some. The two gaskets I have tried felpro and Percy's, were both too narrow overall so (I think it was) the bottom only had about 1/8 inch of gasket in use and that is where it always blew out. Using the copper rtv I have the complete header flange sealing to the head.
  13. #12
    Remflex gaskets since new, going on eight years and not an issue. Percy split-locks for bolts, also still hanging in there.
  14. #13
    Jax Beach, FL
    Copper RTV. I have two studs that I use for alignment. That way you don't smear your RTV around. They have slots cut in them for removal.
  15. #14
    Ottawa, Ontario, Canada
    Ditto on the Remflex, P/N 3083 for AFR heads, port dimensions are 1.38" x 1.40"...use these on my AFR 185 heads, fit is better than any others I have tried. Can buy sheet material and cut your own for the 4 into 4 flange
    Mk IV, 347 AFR heads, WC T5, Solid Axle 3.73
  16. #15
    Mar 2013
    Fort Collins, Colorado
    Ask 28 people and get 28 answers.
    For the header, I use remflex gaskets with a thin coating of copper rtv on both sides . Even if remflex says not to use any rtv.
    Copper rtv with no gaskets on the side pipe flange.
    MK2 #3319.... On the road since 2002 with a lot of upgrades
  17. #16
    Senior Member jrcuz's Avatar
    Stafford Virginia
    I used Copper RTV, also used ARP studs instead of bolts for the headers.
    JR
