Thread: installing dash aluminum
    I am having a problem fitting the one piece aluminum dash. The frame gets in the way just a tad before it goes all the way down. Any help?
    Senior Member rj35pj's Avatar
    Marion, IN
    Protect the frame from being scratched with tape and then flex (bow) the dash just a "tad" to get it in. Another option might be to trim the edges just a "pinch".
    I cut my dash in half to make it easier to wire and to fit it in without scratching everything....just a thought.
    First Time Builder DARKPT's Avatar
    West Alabama
    I had to trim mine a little to fit. You might also find out you need to trim the front of the dash a little so that the body can sit on the mounts provided.
    Coupe #497 delivered 7/29/10. Engine in on 10/1/10. Pushcart on 10/4/10. First start on 12/01/10. First go-cart on 12/31/10. Finished and on the road as of February 2012.
    Coupe Body Buck Plans - My Spray Booth - Painting Lessons Learned
    Build site: www.bamacoupe.blogspot.com
    Lots of build photos and some observations: http://www.flickr.com/photos/53614858@N05/
    Senior Member turbonut48's Avatar
    Milwaukee, Wi.
    You also may want to consider making it 2 pieces. A front and a top panel.
    Makes the wiring and other finishing a lot easier.
    Im going to modify mine to 2 piece soon.
    The Nut
    Super Moderator
    Richmond, ca.
    Making the dash two pieces is the one main thing I wish I had done. If I ever have to pull my dash out I'll copy the one I made for russ Foster! :-) The easiest way to do it with a stock dash is cut it about one inch back from the bend and get some 1" flat stock aluminum at Home Depot, pop rivet it to the front piece so 1/2" is exposed and use nutcerts to attach the other half
    Senior Member EBarnes's Avatar
    Peachtree City, GA
    You guys are awesome. I save so much time, and minimize headaches, by learning from your experiences!
    Milwaukee, Wi.
    I dont know about " awesome", maybe just lazy in my case.
    The Nut
