Thread: Heater Mods
    May 2018
    Heater Mods
    I mocked-up my heater over the weekend, and the template holes all line up fine. My question is this: the only thing holding the blower to the inside heater core is 6 little screws into plastic. Doesn't seem like a very sturdy setup. The instructions say to use a little Hi Temp RTV silicone on the inside to prevent air leakage. I suppose using more of the silicone, all around the air passage might add some strength to the assembly. Has anyone run into a problem with blower/core connection coming apart, and are there any suggested mods to strengthen this connection? Thanks!
    Raleigh NC, OIB NC
    So far so good over a few winters. Been in place for 10,000 miles since March 2015
    Kevin
    MKIV #8234
    BadAsp427's Avatar
    Greeneville, TN
    I have to tell you, I followed the instructions and did the silicone and 6 little screws. Everything seems to actually be pretty sturdy with no problems. I did put the silicone on both sides of the firewall.
    Oct 2017
    i did something a little different. See post #28.
    https://www.ffcars.com/forums/17-fac...191-build.html
    MK4 #9191, Gen 3 Coyote, T56, 2015+ IRS, ABS, 12.88 Wilwood's, FFR Tubular Front LCA's, FFR Spindles
    So. Bay (So. Calif.)
    I've not heard of any problems with that mounting, BUT... I just had to do something better. Here is what I did. https://thefactoryfiveforum.com/show...g-modification
    Syracuse, NY
    Instead of using silicone, I used 3M strip caulk. I figure, if the heater core ever leaks, I can easily remove the unit for service, as the strip caulk is not an adhesive. The six screws seem to be adequate for attachment.
    https://www.amazon.com/3M-08578-Blac...gateway&sr=8-3
