Results 1 to 5 of 5
Thread: New MK4 spindle problem
    Well today I begin work to switch out my donor spindles for the new MK4 spindles to improve the handling.
    Surprise !!!!!!!! The new spindles do not have a mounting place for the ABS pickup sensor. The hubs have the ABS ring....but alas of no use without the sensor. And I really like having ABS.....and it was a lot of extra work to install it and make it work.
    Has anybody else encountered this? What did you do? Any workaround or solution to keep ABS? If not what is best way to disable ABS?
    Thank you
    CamrCobr
    Norton, MA USA earth
    Is there any way you can make a bracket to hold the sensor?
    Feb 2017
    Russ Thompson makes a slick and easy little mounting bracket.
    Quote Originally Posted by frd2 View Post
    I looked on his website and did not see a bracket so I sent him an email. I sure hope he does have a fix for me. Thank you for pointing him out to me!
    Camrcobr
    Feb 2017
    Moose Jaw, Saskatchewan, Canada
    If you look thru the ABS install that the johngeorge race team did they built their own bracket to mount the sensor.
    http://www.johngeorgeracing.com/word...sinstallation/
