![BluePrint Engines](https://www.factoryfive.com/wp-content/uploads/2015/12/BluePrint_Engines_Factory_Five_banner_ad_revised.gif)
New MK4 spindle problem
Well today I begin work to switch out my donor spindles for the new MK4 spindles to improve the handling.
Surprise !!!!!!!! The new spindles do not have a mounting place for the ABS pickup sensor. The hubs have the ABS ring....but alas of no use without the sensor. And I really like having ABS.....and it was a lot of extra work to install it and make it work.
Has anybody else encountered this? What did you do? Any workaround or solution to keep ABS? If not what is best way to disable ABS?
Thank you
CamrCobr
Is there any way you can make a bracket to hold the sensor?
Russ Thompson makes a slick and easy little mounting bracket.
frd2
I looked on his website and did not see a bracket so I sent him an email. I sure hope he does have a fix for me. Thank you for pointing him out to me!
Camrcobr
If you look thru the ABS install that the johngeorge race team did they built their own bracket to mount the sensor.
http://www.johngeorgeracing.com/word...sinstallation/
![Martin's Dent and Collision Shop](https://www.factoryfive.com/wp-content/uploads/2019/02/martins-dent-shop.jpg)
