Hi guys,
Need some help here. I got a new Delphi A/C compressor for my build. I forgot to check for oil before installing it. Any of you guys know if they come with oil on them or not?
Hi guys,
GenII GTM #354
Delivered (02/09/11)
Some do, some don't!!! Ask me how I know!! Mine didn't which, like you, I discovered AFTER the engine was in. I removed the header, undid the comp. mtg bolts, pulled the comp out from the mounts so I had access to the fill plug. Made up a dipstick and checked for oil. DRY!!! rigged up some tubing and a funnel, and filled it with the correct amt. of oil plus leak-check dye, re-assembled. A real PITA!!! Kicked myself for forgetting to check it after it arrived, so much easier to do on the bench.
HTH.
Cheers, Jeff
PS...Don't know why SSP is such a PITA to deal with, they're getting a really bad rep.
GTM 422, LS6, cam, heads, Mendeola trans
[QUOTE=claybags;36303]Some do, some don't!!! Ask me how I know!! Mine didn't which, like you, I discovered AFTER the engine was in. I removed the header, undid the comp. mtg bolts, pulled the comp out from the mounts so I had access to the fill plug. Made up a dipstick and checked for oil. DRY!!! rigged up some tubing and a funnel, and filled it with the correct amt. of oil plus leak-check dye, re-assembled. A real PITA!!! Kicked myself for forgetting to check it after it arrived, so much easier to do on the bench.
HTH.
Cheers, Jeff
PS...Don't know why SSP is such a PITA to deal with, they're getting a really bad rep.[/QUOTE
Thanks for the reply Jeff. Just got and email from the place I ordered it and he confirmed that mine comes dry.
About SSP, over the phone Steve sounds like a real pleasure to do business with. Very accommodating to any custom requests on the harnesses but in the end there was always a new excuse for not being done with it. I did have a horrible experience with them. Did you order something from them?
GenII GTM #354
Yeah, I got a semi custon engine harness plus a re-man ECM. Took a while, but I am in AZ . Harness was very nice, ECM..well, kept getting a code that my 4 wheel dr P/N was screwed up, so I don't know what it was out of. Then started hearing stuff about him among the local tuners, so I went somewhere else. Too bad.
Hey, I was anchored out in the bay there a few years ago, I shoulda' looked you up had I known LOL.
Cheers, Jeff
Cabo Rojo. Hung out for a few days before crossing the Mona Passage to the DR. Fun time!!
Cheers, Jeff
More precisely...Boqueron
Well, we were on our way to Florida from the Meditteranean after spending 4 years in Europe. Now with a GTM, I fear my sailing days are at an end! LOL
Cheers, Jeff
I removed the compressor last night and took it to the shop of a friend to add the required amount of oil. I always like to see the positive side of things, even in situations like this one where I forgot to add the oil before the install. I had to pull the compressor to add the oil but the good thing was that I was able to read the serial number of the engine which is hidden behind the compressor. I will need that number when the time to register the car arrives. I was also able to solve another problem I had. The connector on the compressor is located at about 8 o'clock on the stock C5 compressor. This created a clearance issue with the chassis. As soon as the engine would have moved on hard acceleration or deceleration it would have broken that connector from the compressor clutch. I had even marked the chassis to modify it to gain some clearance. After pulling the compressor I noticed that there is another notch at about 2 o'clock on it that can accommodate the clutch connector. So, I asked my friend to pull out the clutch and relocate the connector in that notch. No more clearance issue there.
Before
After relocating the connector
GenII GTM #354
That's where it is... I knew that I had seen it. The person that I spoke to said that it was on the front of the block on the passenger side, just below the head. I understood that to mean somewhere around the water pump. But then I vaguely remembered seeing a lazer etched serial number on the side of the block, but couldn't remember where.
That will sure help some other people here! Thanks for posting this!
The Stig
GTM #0081
Kempo, How much A/C Compressor oil did you add ?
Joe
Joe,
7 oz were addded to the compressor. There will be another 3 that will be added with the refrigerant.
GenII GTM #354
