Likes Likes:  2
Results 1 to 11 of 11
Thread: What is the best way to patch drill holes in the powder coated frame?
    Atlanta, GA
    After drilling all the holes for the original side engine bay full aluminum panels, FFR changed the panels to half panels presumably for better engine bay ventilation. Now that I have these panels, I would like to patch the holes in the frame that are no longer covered by the panel. After chamfering the hole, I tried black GE Silicone II. It works ok, but not great and I question the durability. I suppose I could fill with Bondo and then recoat with Rustoleum brush on or Rustoleum Epoxy Appliance Spray. That seems like a leap of faith. Has anyone had good results in this process? What did you use?
    Gen 3 Coupe, Gen 2 Coyote, Wilwoods, IRS, Power Steering, AC JDAVIS500 Build Thread
    Senior Member Alphamacaroon's Avatar
    Jan 2019
    Richland, WA
    What about just filling them with rivets again? If you want it totally smooth then it's not an option, but it will definitely look better than filling with Silicone. I mean, the only thing that looks cooler than rivets, is more rivets, right?
    Quote Originally Posted by Alphamacaroon View Post
    My thought exactly.
    Atlanta, GA
    You make a good point. It reminds me of the recent story about the Russian model who covered her Aventador Superveloce with Swarovski crystals.
    https://www.forbes.com/sites/guymart.../#5e7c212e78e5
    Insert joke here.
    Jan 2019
    Richland, WA
    She's ahead of her time— those are "crystalline laminar flow boundary layer separation speed dimples". Since yours are internal, you can call them "venturi-style frame overpressure pop-off vents"
    X3 on the rivets. That's what I did too. Just don't tell anyone they don't do anything...
  7. Likes Ducky2009 liked this post
    Colorado Springs
    Fill them in with JB Weld, it will last just about forever. Then sand and repaint.
    .boB "Iron Man"
    www.RacingTheExocet.com
    May 2019
    New here, and I know this has probably already been taken care of, but JB Weld also makes their product in a putty form that may work better than the liquid epoxy version. For rivet holes, you could use a very small ball of the putty, push it into the holes and would take less smoothing before paint.
  10. #9
    Bakersfield, CA
    I like the rivet idea
    Build thread
  11. #10
    West Linn oregon
    Talking
    There happens to be an acronym for a rivet used to fill a unused hole,,,, RTN,,,,rivet to nowhere!
  12. Likes SSNK4US liked this post
  13. #11
    Milton,DE
    I little late here but...rivets. Use black ones if you want.
    Olli
