Thanks Thanks:  2
Results 1 to 11 of 11
Thread: Roadster rear coilover alternative #14675
    Apr 2019
    Just picked up a roadster and the first thing I wanted to order has been on back order for 8+ months now. Are there any viable alternatives to the #14675 rear axle coilovers?
    Quote Originally Posted by ssscarpone View Post
    If you are relying on the availability information in the "parts catalog" section if the FFR website...don't. Items are often listed as out of stock when they are not. Call them.
  3. Thanks ssscarpone thanked for this post
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    X2. It's always worth a call.
  5. Thanks ssscarpone thanked for this post
  6. #4
    Breeze has externally adjustable QA1 coilover kits. FFR single adjustable Koni need to be removed for adjustment.
    https://www.breezeautomotive.com/sho...lb-in-springs/
  7. #5
    Apr 2019
    I already called them and they said end of July before back in stock again. I guess the waiting game continues.
  8. #6
    Nov 2018
    Do the QA1's use the same length springs as the FFR Koni? Externally adjustable sure would be nice on autocross days!
  9. #7
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    You can also check with Gordon Levy for shocks as he carries Koni shocks
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    615,215 miles as of 4/23/2022
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
  10. #8
    Mar 2013
    Medway, MA
    We use 9" springs on the front and rear but 8, 9 or 10" will fit the rear.
  11. #9
    Nov 2018
    Quote Originally Posted by Mark Reynolds View Post
    Mar 2013
    Tucson, Arizona
    After several years of suffering I changed out all the springs that came with my Mk4. Glad I did. About 75 in./lbs less worked for me.I also softened the Konis at the same time. I have the removed springs (FFR) as well as 50 in./lbs less. Send PM if interested.
  13. #11
    BadAsp427's Avatar
    Greeneville, TN
    PM sent... I have a set you may want.
