Just picked up a roadster and the first thing I wanted to order has been on back order for 8+ months now. Are there any viable alternatives to the #14675 rear axle coilovers?
Breeze has externally adjustable QA1 coilover kits. FFR single adjustable Koni need to be removed for adjustment.
https://www.breezeautomotive.com/sho...lb-in-springs/
I already called them and they said end of July before back in stock again. I guess the waiting game continues.
Do the QA1's use the same length springs as the FFR Koni? Externally adjustable sure would be nice on autocross days!
You can also check with Gordon Levy for shocks as he carries Koni shocks
Ralph Button
FFR 1436 (PROUD Owner of an Original Mark I)
400,013 miles as of 11/1/2009
417,840 miles as of 8/12/2010
435,021 miles as of 12/19/2011
Now a well broken in 347 engine
523,145 miles as of 7/29/2014
601,165 miles as of 6/1/2018
615,215 miles as of 4/23/2022
"It's not about the destination, it's the about the journey. And where is your journey taking you?"
"... Not all who wander are lost!... --J.R.R. Tolkien
We use 9" springs on the front and rear but 8, 9 or 10" will fit the rear.
After several years of suffering I changed out all the springs that came with my Mk4. Glad I did. About 75 in./lbs less worked for me.I also softened the Konis at the same time. I have the removed springs (FFR) as well as 50 in./lbs less. Send PM if interested.
PM sent... I have a set you may want.
